View the thread, titled "What electric works can plumbers undertake" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello all
I’m looking for some clarification as to what electric works plumbers / heating engineer can undertake. It seems to be a grey are with part p defined scope etc which I believe has gone? And that part p is just a building Reg and not a qualification. So in light of my confusion some help is wanted.
so what can a plumber / heating engineer do. I mean with no electrical quals or part p.
I don’t just mean that they have the skill to do it but they have the legal right to do it. Aren’t breaking any buildings regs etc
can a gas safe heating engineer wire a new boiler into an existing fused spur even in a kitchen . ?
Can a plumber replace like for like electric shower
can a plumber replace a heating system component such as a zone valve, pump, thermostat - including wiring it into wiring centre
can they fit a new room stat as part of a new boiler
I very much believe in doing things correctly and doing the best I can.
So for me to be clear In my head lol Can a plumber Wire into an fcu (which I understand to be a fused connection unit at the end Of a spur or even on its own circuit from consumer unit) - a shower pump, a boiler, an immersion heater for a hot water cylinder. and also a zone valve and pump wired via the wiring centre. I’m envisaging the common situation face by plumbers whereby one is broken and needs replacing like for like.
Can this be done without being qualified electrically?
is it notifiable or minor works etc such that an electrician is required each time you want to swap a heating system component.
My understanding is that 'installing fixed electrical equipment is within the scope of Part P, even if the final connection is by a standard 13A plug and socket, but is notifiable only if it involves work set out in regulation 12(6A).' (ADJ, p.7)
I used to think that this heating control wiring needed to be carried out by a competent person or be notified under the building regulations. I have since been advised (on this forum) that this isn't what is meant by control wiring (which is, or used to be, notifiable).
In practice, I would rather do the work and then ask an electrician to check and formally sign the work off as most electricians understand electrical safety but not heating controls. This relies on a good working relationship with an electrician, however. It is worth noting that it is would be a small minority of electricians that would go to the effort of testing and recording the replacement of, say, a lamp pendant, provided the light goes on and off with the switch.
I suspect the technical answer is that while a lot of those works )even a directly like-for-like replacement of an electric shower) may not technically require to be notified, they still need to comply with the building regulations. As we are plumbers and do not have a comprehensive understanding of BS7671 (The IEE regs), nor do we have the specialist calibrated equipment with which to test any work we may carry out, then technically we would be unable to ensure that our non-notifiable work is 'inspected, tested and certificated in accordance with BS 7671' (ADJ, p. 10).
Here's my opinion for what it's worth.
A plumber with literally 'no electrical quals or part p.' should not be doing any work involving electricity in a customer's home until they have passed a recognised 'basic electricity for plumbers' course. This will teach you things like isolation, proving isolation, visual inspection, simple electrical tests using a multimeter, preparing and making straightforward connections, etc. It will also make it clear what you are and are not qualified to do. If you tell the instructor what sort of work you want to do they'll be able to say whether you're covered or which additional course(s) you need to take.
This is largely for your own protection. You do not want to injure yourself (hence the 'isolation') and you don't want to be the totally unqualified plumber who is being accused by a customer of incompetent electrical work.
Firstly, make a list of what you want to be able to do and contact your local college to see what they have on offer in the way of suitable courses. Secondly, try to develop a good working relationship with an electrician who can help you out with small jobs if necessary.
As we are throwing in opinions. Mine would be the fact that if the wiring is powering something that is already in place then an Heating engineer can wire up any part of the heating system he wishes as long as he holds the correct qualifications for that appliance. If however, he was taking out storage heaters and and immersion heater and putting a combi in the kitchen and a new spur is needed then a sparks should be doing the works. Or an engineer with electrical qualms.
Where are these electricity for plumbers or basic electricity for plumbers courses? any recomendations
Here's an example of the sort of thing I had in mind:
I'd always start with a local / regional further education college as their courses are usually good quality and good value. If you're going to spend a significant amount on a course do your research and make sure you understand what you are getting and who will be teaching assessing and accrediting it before signing up.
While I agree with the opinions being ventured in this thread, I'm not sure whether they answer the question, which was, I think, "technically and legally what should we do?"
Reason I say this is that someone with an Intermediate Amateur Radio Licence is allowed to build his or her own radio (mains powered electrical), having (usually) studied the RSGB material. But then this person is not considered to be electrically qualified. The irony is that while I have been assessed as competent to wire a so-called "13A" (technically a BS1363) plug and build my own amateur radio as far as the RSGB is concerned, I'm not qualified to do so in other fields, even though it's exactly the same plug!
Why is this relevant? It's relevant because the C&G NVQ2 course contains an electrical element.. We are taught how to carry out very basic tasks such as junction boxes and FCUs and the safety aspect at a basic level and then told this isn't a qualification. Why, then, are we being taught this, if it doesn't make us competent? Well, because C&G knows you'll probably end up doing this sort of thing anyway and they'd rather you had at least a basic level of electrical education (my assessor's answer).
Similary, the BPEC course gives you a level of knowledge that then still doesn't make you a competent person. Not that I don't think it's a good idea, though useless to plumbers who lack the ACS CCN CEN gas certificates (pre-requisites). 'It has been designed with plumbing and heating engineers in mind and is limited to work that will NOT involve working on fixed installation of the property and addresses the following scope of work.' So you still wouldn't be legally allowed to do anything except repair the boiler, I take it?
Does competent mean having a certificate?
If a third party looks at/tests an installation and all is done to regulations and in a neat/tidy way then they would have to come to the conclusion that it was done competently.
This assessment of the work could not determine who it had been done by...
So does it matter if this was carried out by an electrician, brain surgeon, footballer or trained monkey?
Yes, it means a certificate. Hence some of the shoddy electrical work I see was carried out by 'competent' persons.
Not just this.
No decent sparks sign off 3rd parties work - why would you?
What I come across is plumbers adding spurs to spurs, disconnecting the main equipotential bonding, and replacing showers without RCD's or a higher rating with insufficient cable size and / or breakers
Why is this relevant? It's relevant because the C&G NVQ2 course contains an electrical element.. We are taught how to carry out very basic tasks such as junction boxes and FCUs and the safety aspect at a basic level and then told this isn't a qualification. Why, then, are we being taught this, if it doesn't make us competent? Well, because C&G knows you'll end up doing this sort of thing anyway and they'd rather you had at least a basic level of electrical education.
insurance if something went wrong ? One big consideration is what piece of paper are your insurance company going want to see if anything you do goes wrong.
Not just this.
Same as if gas engineers sign off other engineers installs(you wouldnt)
Not just this.
'All to regulations' includes the fact that the original installer either notified to Building Control and had independent testing carried (in England - think Wales is slightly different) or was a member of a competent person scheme. Not just doing notifiable work well but without being able to leave the relevant certification.
The insurance question is a good point. Which is why I suggested working alongside a friendly electrician. That said, I have replaced a valve actuator by myself. Not notifiable, and I'm not sure how much testing a real electrician would be doing, but possibly I've not tested to the BS. Admittedly, I suppose it's a risk.
I have in the past installed a shower pump in an airing cupboard, agreed to do the plumbing side but not the electrical side, i.e. comission the pump with a plug on the end of the flexible cable, and then remove the plug, leaving the customer to get an electrician in to wire it in to the manufacturer's specifications, as indicated on my invoice. If the customer then ignores my advice and refits a plug, that's up to the customer.
You can hold a certificate yet be incompetent. You can be competent without holding a certificate and perform work of a very high quality without any qualification. This is how things used to be. Now an industry has developed to charge for training and then for registration, another tax upon trade. Things may well be better under this new system, but not always because mistakes still happen. Try buying a new build.
Competent just means “having the necessary ability, knowledge, or skill to do something successfully”.
Would you replace a broken shower pump. I.e plumbing side and also unwire old pump from fcu and wire in the new one to fcu or would you get a spark to connect the 3 wires? The same for a zone valve would you replace one for like and do wiring into wiring centre?
would you replace broken immersion heater in water cylinder and wire that to fcu
it’s the sort of thing that a lot of heating engineers / plumbers do but should they?
it’s such a grey area I’m beginning to wonder if it’s worth the risk. It seems to me these like for like component jobs are a two person job plumber and spark.
I’m trying to find a definitive answer as to who can wire into an fcu
practically competent and legally competent are different I think .In the end insurers etc are going to want to see evidence that you have the skill and knowledge to do something. Sadly I think this means a bit of paper
I'd do them because it's not notifiable work, being like for like. It would depend on the customer and also if I felt the existing electrical system was up to current standards or whether it was essentially running on grandfather rights.
What I would comment, however, is that, legally, I probably shouldn't because testing with a 1960s AVO8, if at all, is not to standard, but at least I can check the earth is connected. If I had a lot of this work, then I would pay for the training and the calibrated tools, but in the meantime there is, sadly, a limit to how much work I'm able to turn down. What I would say though is that the instances of court cases and prosecution of which I am aware generally invole a far greater level of negligence than mine.
it’s the sort of thing I know
thank for your reply. It’s more of the insurance issues if the house is damage or customer gets hurt than the prosecution side. Insurance companies will always try not to pay.
Agreed. I'd only do it if I were 100% confident in the work. Obviously the customer getting hurt is a big one.
absolutely nothing wrong with plugging the pump in ....
As a heating engineer. I would expect us all who carry the title to be able to take all wires out of a multiple zone plain 10 way junction box, mix them all up and be able to put every single wire back where they should be and the system to be working exactly as it was when you arrived. If you can do that then, a live, neutral and earth into a fused switch should be a doddle.
Couldn’t agree more. But is it legal to do. Will insurance cover it if it goes wrong. And what qualifications / training does one need to satisfy both those points.
Except that by law all electrical goods that MAY be plugged in MUST come with a plug fitted. So Stuart Turner, who supplied the pump without a plug had to maintain the fiction that it MUST be wired back to an FCU. It's only wrong, hence, in that it is not in accordance with MI's.
I suppose that there is a risk of the plug terminals oxidising as they are not subject the abrasion of being pulled in and out occasionally. Realistically, though, in my own house I'd be perfectly happy with a plug and socket connection.
C’mon guys let’s get real, we can’t let it happen that you have to get three qualified men in when you want to change a light bulb.
The ladder man, unscrewer/screwer and the health and safety officer - that might be four actually...
Reply to the thread, titled "What electric works can plumbers undertake" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
midsman,
Harvest Fields,
