what kind of pipe is this - water leak
View the thread, titled "what kind of pipe is this - water leak" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all
hope you are all well .
Is the pipe in the photos lead or steel ?
I suspect its leaking further down (water) as there is a puddle and I could hear running water until i turn the water off in the street
thanks!
If this is in the UK, I'm fairly sure it's not a water supply pipe but not because of its material. It's is not buried deep enough with respect to the surrounding ground level and would freeze during the winter.
Like @ShaunCorbs, I'd err on the side of caution and assume it's gas until further investigation proves otherwise.
Reply to the thread, titled "what kind of pipe is this - water leak" which is posted in UK Plumbers Forums on Plumbers Forums.
kimeddie,
cjg,
