View the thread, titled "What size flexible oil hose on Danesmoor 15/19?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Does anybody know off the top of their head what size flexible oil hose is required for the above boiler?
Father in law informs me his is leaking (or at least thats where he thinks its coming from) so I'd like to pick the right one up to avoid two journeys if it is that at fault.
what ever fits the fittings the installer put on in the first place! not helpful but true
I see, I just presumed it was a certain size for that boiler! Do you know what size it'll be into the oil pump........1/4 male angled?
Could be anything. Depends on what the manufacturer used at that particular time, or whatever some service guy has used. Some put any old thing on.
Worcesters tended to use 1/4" hoses with one bent end, but sometimes the bent end was male for into pump and some were female for onto a hose nipple.
Thanks all, I'll grab a selection from the merchants and take back what I don't use, that way I should have it covered!
:smiley2:
And get a few hose nipples! 1/4x1/4" and 1/4x3/8" as sometimes needed.
I like to always have nipples. :smile:
Reply to the thread, titled "What size flexible oil hose on Danesmoor 15/19?" which is posted in Boiler Advice Forum on Plumbers Forums.
