What size is the small connector on the valiant 837 filling loop?
View the thread, titled "What size is the small connector on the valiant 837 filling loop?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
V
Valiant Problems
Hi Guys,
The valves on both sides of my Valiant 837 filling loop are letting through causing a constant pressure rise (seems to be a common problem). I want to cap off or isolate the small connector but its not a size I recognise, the part number for the filling loop is 0020010293. Can someone please let me know the size of the small connector.
Many thanks in advance.
Not sure about size; but when I'm stuck I disconnect the larger sized flexi hose union from the boiler and reattach it via a ballofix or equivalent valve and a 1/2 inch to 1/2 inch female flexi (so you end up with two flexis with a new valve in between)
Reply to the thread, titled "What size is the small connector on the valiant 837 filling loop?" which is posted in UK Plumbers Forums on Plumbers Forums.
Valiant Problems,
tamzbackforalook,
