Thanks you for your reply mate1. Look like standard 1/2" BSP (threaded) x 15 mm compression.
2. Shouldn't be too difficult to find. New valves normally come with them.
3. Have a look at Replacement TRV Rad Valve Tail 1/2 Inch Standard - https://www.monsterplumb.co.uk/replacement-trv-rad-valve-tail-half-inch-standard?gclid=EAIaIQobChMInJ_QlMTF9QIVFu3tCh01Fg1uEAQYAyABEgIbKPD_BwE (ignore the "thermostatic" bit).
Hi, I need them because I’m changing a radiator using the same valves as like for like swap in size and can’t for the life of me get the tails out the existing one. No idea what they have used to put them in but they are in solid
Or a plumber’s merchants.
Why do you need them? If you’re replacing valves, they generally come with new ones.
just looks like ptfe tape? Maybe they’ve cross threaded them?No idea what they have used to put them in but they are in solid
No, mind control 😂😂😂😂It’s only ptfe are you using a spanner ?
Lol all sorted now thanks for your reply everyone 🙂No, mind control 😂😂😂😂
Reply to the thread, titled "What size radiator tails are these?" which is posted in DIY Plumbing Advice on Plumbers Forums.
