View the thread, titled "What size tap is this?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, I am trying to fit a hosepipe to this tap (photo attached). I bought a 3/4 female adapter which is too big for the tap. I tried a 1/2 adapter too (shown on photo) but it is a fraction too small for the tap. Any advice welcome! Thanks
It's 5/8", common on older bib taps.
Sometimes in the multifit plastic adapter kits you get one.
It's easier to change to a new tap.
Or there's this
1. If your measurement of the diameter is 13/16", that equates to 20.6 mm. The outside diameter of a 1/2" BSP (parallel) thread is 20.8 mm, so I suspect the thread is 1/2" BSP.
2. Are you sure that plastic adaptor you are trying to fit is 1/2" BSP? If not try it with something known, like a 1/2" blanking cap, such as Screwfix 51939.
3. Or change the tap as suggested above.
Reply to the thread, titled "What size tap is this?" which is posted in UK Plumbers Forums on Electricians Forums.
