View the thread, titled "What size/type valve is this for kitchen mixer tap" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi please can you help? What size/type valve is this? I previously asked a plumber and was given the wrong size🙁
There are about half-a-dozen dimensions that can vary and some of these need to be measured quite accurately (+/- 0.5 mm). It is possible to do this with an engineer's tape measure with a mm scale but you really need to use a pair of calipers. See, for example:
If you take the cartridge along to your local plumbers merchant they will probably be able to find a match for you.
Reply to the thread, titled "What size/type valve is this for kitchen mixer tap" which is posted in UK Plumbers Forums on Electricians Forums.
