View the thread, titled "What to fit, hot water system in flat, electric supply only!" which is posted in Bathroom Advice on UK Plumbers Forums.
sebpalmer
Hi all,
If you could be gently with me as its my first time .. here.
I've got a flat and the hot waster system needs changing immediately.
the old system was a direct vented copper cylinder, originally coal fire back boiler heated but as fire was changed a few years ago it has been running off immersion since then.
The copper tank was leaking from corrossion and the immersion timer has packed up so ive just took it all out today.
my question is what do i need to get my hot water back.
I can work with copper and got all the tools and it looks like the most basic hot water supply ever, so hoping I can do it myself with your help!
Can I just fit a new direct vented tank with 27" long life immersion heater and new timer? Do I just blank off the boiler flow/return outlets?
got loads of pics if they work...
Yes, if you want you can buy a cylinder with or without direct tappings. You can also get cylinders with 2 side Immersion tappings for 2 shorter 14" immersion elements. What is heating flat, electric heating?
standard direct cylinder should be fine, go for a cylinder as close to the size of the exsisting one and it will minimise pipework alteration. If you are unsure then please get a qualifed plumber to do the work.
i would go for a cylinder with 2 immersor boss on the side and upgrade the wiring to get off peak, as this will save a fortune in the long run, off peak electricity is also the way to go for heating the place as well,
I would even reccomened getting a qualified installer in and having an unvented cylinder. Much better water pressure and flow if the main is capable
If you don't get a qualified installer. You may find your insurance void
Reply to the thread, titled "What to fit, hot water system in flat, electric supply only!" which is posted in Bathroom Advice on Plumbers Forums.
