Jul 27, 2025
Havant
DIY or Homeowner
This pipe is coming through kitchen ceiling, presume it’s an obsolete vent pipe. I want to cut it back further into loft void. Am concerned the honeycomb seal is asbestos. Any advice as to what it was for, and would it be safe to cut back, or leave well alone and just box it in.
Thank you
These days, you always assume asbestos until a lab test on a sample proves otherwise.
To me, that looks like an old asbestos-cement flue thats someone has sealed by stuffing a cylinder of expanded polystyrene up it. The usual options are (a) to leave it undisturbed and protected from damage or (b) get it removed by a licensed contractor.
Having known several people (one of them was my doctor) who have died relatively young from mesothelioma I would strongly discourage you from a DIY attempt to 'cut it back further into loft void'. In my opinion, that's a job that should only be done by licensed professional with the right equipment to contain the dust that will be created.
Thanks Chuck for the sensible pragmatic response. Makes sense it was probably a flue pipe as it’s near a previous boiler site, but pipe itself appears to be zinc.
I will err on the side of caution and leave alone.
Does the pipe pass through another room above or is it a single-storey property and it's just the loft above?
Is it possible to see the pipe above and determine what type of joint if any there is in the pipe, if it's a socket it could be asbestos, if it's a threaded joint it will be galvanised iron.?
