Where can I buy this exact isolation/service valve?
View the thread, titled "Where can I buy this exact isolation/service valve?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
The isolation valve connected directly to our toilet fill valve has started to leak (I assume the washer has deteriorated). I'd like to get a like-for-like replacement so that I can just do a straight swap of the entire isolation valve without having to worry about resizing pipes, but my google skills have failed me (I'm a DIYer/Homeowner so not sure exactly what I should be searching for). Does anyone know where I can find this exact model? If not, can someone recommend a similar one I can use in its place?
Picture is from another user who posted a thread on this back in 2017, but I have this exact same valve.
its called a straight service valve. It will be 1/2" one end 15mm the other, basically what I link below but not the same one.
I doubt you'll find an exact copy though. You'll need to get a 15mm pipe slice and some jointing compound an adjustable spanner and grips.
Reply to the thread, titled "Where can I buy this exact isolation/service valve?" which is posted in UK Plumbers Forums on Plumbers Forums.
ricster2000,
ricster2000,
