Ted808
372
61
28
58
Folkestone
www.planetplumbers.co.uk
Heating Engineer (Has GSR)
This a mix of material pipework and sizes. It's steel (what size?) and 35mm copper 28mm copper. I need to replace the leaky bit and tidy it up if I can.
Where can I get the reducer from what I think is 2" steel to 28mm copper?
Any pointers?
That’s a union so just needs stripping and pasting
Can I get a threaded connection, to replace the union? What would it be called? Female iron 2" and MI 35mm ?
The leaking bit isn't the union. There's 35-28 copper reducer coupler that probably wasn't soldered and the fella wants the pipe work nearer the ceiling. So, that's why I'm looking to replace the union if i can, but I don't know, what size or where to buy tehm.
Reducing iron socket 2" (if that's what it is) x 1", then 1" x 28mm compression straight or elbow, whatever suits the new layout.
For iron you'd need Pipe Centre or BSS or other independent iron pipe and fittings supplier.
Similar to this,
Measure the width of the of the steel tube 1” measure 11/4” od etc
UK Plumbers Forums
Deleted member 120897
