Where is the air coming from
View the thread, titled "Where is the air coming from" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
Hi, I've had a water hammer / knock. I've done the switch mains off - switch all taps on - switch main on - switch taps off procedure. It worked, no water hammer. However, few moments later, I switched on the tap in the upstairs bathroom (it's a 3 storey victorian property) and lots of air came out / water sputtering, when I switched the tap off, water hammer was back! very annoying.
Any ideas of where is the air coming into the system?
Thanks!
T
Hi, thanks for your reply. I just followed the instructions on several website about how to get air out of your system... I guess that was the wrong thing to do?
Is there anything else I can try?
Thanks again,
T
Simply needs to clip there rattling pipes
You could fit a shock arrestor to help the problem but this is more of a bandage than a fix
It occurs when a tap is switched off. I found that when I reduce the water pressure the hammer disappear too but it's not a great solution :/
That type of hammer is often due to the pipework not being clipped firmly and at sufficiently frequent intervals. For 15mm pipe, clips should be no further apart than 1.2 m on horiztontal runs and 1.8 m on vertical runs. More detail here:
Thanks everyone. I guess there is no solution then? I mean, from what I can tell most/all pipes go inside the walls and behind cupboards, how would I find where they need to be clipped 😳
Sorry if this sounds stupid but I wouldn't even know where to start
Hi
Also alot of water hammer noises are also caused by a bad gland or valve jumping.
You could have a bad cartridge in a tap. You can normally feel the tap vibrating.
It might be easier to get a professional in. Check the incoming pressure and if need be install a pressure reducing valve with a gauge. It can sometimes improve things and you can also see if the stop tap gland is jumping affecting the whole property. Hope this helps.
Reply to the thread, titled "Where is the air coming from" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
Thread starter
Joined
Location
London
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
None
Tuli,
Warmiger,
