Where would you terminate basin waste?
View the thread, titled "Where would you terminate basin waste?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
WaterTight
Subscribed
Basin waste going to come through under coloured square little window.
Where would you terminate it?
Also excuse my ignorance part 2536452 but is it safe to just hop up on a ladder and walk about on this roof or should there be some safety proceedures to follow to protect it/myself that I'm likely unaware of?
I think I've stood on about 3 roofs in my life and never been quite sure to what extent it's a good idea. Ta
[automerge]1565806999[/automerge]
It looks like the vertical stack is cast iron?
In which case I would bring it to the right and drop it into the top of the plastic 4”.
That was my current best laid plan
Whats with the sheet of whatever covering the soil pipe , there’s something else look like its trying ti poke through ..... flue ??
Stack on the left using a mechanical boss
Roof is fine to the left but don’t stand / walk on the polycarbonate on the right
If the brickwork’s straight there doesn’t appear to be enough fall on that 4”, dropping the basin in the top may help move things along a bit.
Using the existing boss as Dave suggested will be easiest, as long as the weathering does not interfere.
Although I’m not keen on joining horizontal wastes at the side, I prefer the top, but have done so in the past when necessary with no ill effects.
I would stab it in the 110mm to the right , keep well away from the poly carbonate roof and lay some scaffold boards on the tiled roof to spread your weight . Kop
Are you actually a plumber? Does your client know that you are asking basic questions on a forum?
Are you the same watertight that went under Walter Systems?
Where is that 32/40mm going to around the corner?
Get bent.
Thanks to everyone else, I love you long time.
Reply to the thread, titled "Where would you terminate basin waste?" which is posted in UK Plumbers Forums on Plumbers Forums.
WaterTight,
Phil,
