Guest viewing is limited
which boilers are people fitting with 5 yr warranty
View the thread, titled "which boilers are people fitting with 5 yr warranty" which is posted in Boiler Advice Forum on UK Plumbers Forums.
As long as I can get mark one duotec potterton gold I will continue fitting them
yep and me also the heatmax is the same boiler they really do make the WB look crap,for a start you can change anything on a duotec in half a hour,the prv in about 10 mins
Baxi have sorted all the problems now on the new netatec... Got to say the service from baxi was very very good.
I thinking have fitted over a thousand boilers plus up to now, all different makes and sizes. From on the books to my own work then to contract work now back to just for myself. I fit Worcester or valiant then middle of range boiler I install ideal logic+ . I know these boilers used to be a shower of ****e and I would sooner have no boiler than that pile of ****e. But since the logic+ came out with 5 year warranty I tried and have not looked back since. Easy to fit, customer friendly except position of pressure gauge which you can now get a extender to drop it to eye level for a few pounds. Brilliant digi display. Talk to your local rep get in with him and sell your self. Hope this helps
My local councils are fitting Ideal Logic, mind you Ideal do seem to get on most contracts. Ideal Isar/icos were fitted for years on warmfront and many council contracts.
Must be lots of brown envelopes flying about.
If fitting a Combi, then it's Intergas all the way, don't touch anything else in terms of installing combis. Dead easy to setup for CH and DHW heat inputs for example. Simple to service. Easy access to parts. Good support from the guys at Intergas. Fewer working parts than many other combis. Condenses in DHW mode. Worked on the earlier versions on the market (Atmos Intercombi), only ever came accross 1 heat exchanger that had gone faulty, but that was due to installation error! 10 year warranty on the heat exchanger and it's easy to clean. These are cracking units and are great for building a positive reputation for us installation and servicing engineers.
Reply to the thread, titled "which boilers are people fitting with 5 yr warranty" which is posted in Boiler Advice Forum on Plumbers Forums.
cdodds2004,
Halesowen1,
