View the thread, titled "Which heat only boiler..?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
A
Alex Knight
First off I am a Gas Safe Engineer, I've just never got round to PM my details sorry.
Parents need a new boiler fitted as their potterton netaheat is beyond economic repair.
We generally just fit glowworms at work, which are fine and is what I will go with unless someone can suggest something else. I have looked at Atag as I have heard good things but having never fitted one myself don't really want to make them get one if it's going to be trouble.
All radiators will be new by the time the boiler goes in which should minimise the amount of sludge in system, but obviously if it still looks bad it will get a good flush out, also new three port and cylinder stat to be fitted.
Boiler will obviously be fitted and registered through the company I work for.
So any suggestions? Cheers Alex.
Worcester RI is a cracking heat only boiler. It would get my vote every time. (And I'm not a Worcester man!!)
Thanks, the only reason the flexicom is first choice at the moment is I'm used to fitting them, and 2nd hand spares would be easy to come by.
We are currently fitting the glowworm energy's but not keen on them tbh
Baxi Eco Blue Advance Heat Only,this is proving to be a cracker of a boiler,no pump over run needed either ,you can get the cheaper version but its only a 2 year warranty,personally i would not fit a glow worm,baxi solo or Worcester EcoBlue Advance Heat
Baxi Eco blue (Advance for warranty) , just fitted one, No P/L required, very easy to use, & very quiet, available with rear flue option
I fitted a energy yesterday, why didn't you like it? Don't go down the flexicom route in my opinion are rubbish and I've had to repair plenty of them.
Think they are a pain to pipe up compared to flexicom, if they ever have to come of the wall for repair will be bloody awkward. We think they're a step backwards from the flexicom
Ah OK interesting, I didn't like the connectors you get to go onto the isolators I prefer when elbows are supplied. Not sure how it would be anymore difficult to remove then a flexicom tho as same bracket.
Because the nuts on the energy are awkward to get at once the boilers on the wall
Reply to the thread, titled "Which heat only boiler..?" which is posted in Boiler Advice Forum on Plumbers Forums.
