Which wet/dry vac and powerflusher?
View the thread, titled "Which wet/dry vac and powerflusher?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
N
Nat
Hi all,
Looking for a couple of recommendations please.
For the wet and dry vac I'm looking to pay around £120. Is capacity important? Can you get them bagless? Any of them particularly suited to our job?
With the powerflusher I have a budget of around £800. Is this enough to get anything descent? There is this one on ebay but it just looks a bit 2-bob in my opinion:
Power flushing and descaling pump. | eBay
Really would like to go for something like a Kamco but maybe my budget is too small? Is buying second hand a good idea?
Any thoughts gratefully received.
Nat
Id also be interested in the response to this thread and also How do you guys modify your vacs to fit onto pipes or don't you?
ive got a Charles (wet & dry) version of the Henry. its o.k for water altho in my opinion its capacity isnt great.... it could do with being a bit more powerfull... a mate has one that he bought from wicks about £40ish i think he said and its better bigger capacity and more powerfull... hope that helps.
You seem to be well on the upper end of the market (price wise).
I would suggest a Kamco power flush with the magnaclean attachment and to be honest I have had a £30 Wickes wet and dry that has never let me down and does everything I want. I have had this for 6 years and no problem (at that price its worth a pop).
I dont know the model but its the grey one with the black top.
i got one from ASDA last christmas for £25. earlex i think it is, sucks and blows a treat 🙂
Any cheap wet and dry will be ok really, but its best to get one that does not require different filters/bags so you can just use it from dry to wet with ease.
you dont need a adaptor to fit pipework normally, just hold it over the pipe end.
Sorry I should have said. I only use the Wickes hoover for the wet work and I have a separate one for the services and dry work. (I know that defeats the object but saves fitting and removing filters all of the time).
I think the kamco is more than 800 though
Dry vac ... I use a dustpan and brush.
Wet vac - makes emptying a cistern a 30 second doddle, easy draining a radiator with no mess, great at cleaning an internal pond, etc, etc, etc. I use it less than I did in the past but do find it really useful.
It also impresses customers and it gives them confidence that you're not going to ask them to change into swimsuits.
ive just been looking at this aswell but it doesnt say whether you have to change the filters or not when going from wet to dry, ive emailed them, anybody own it?
I don't think you do as the replacement filters are both wet and dry.
think i'll be ordering it aswell, looks like it comes with a cheap paper filter though so the real price is £45
Looks like I have the earlier model than this and as I stated earlier (grey body and black lid), I only use it for wet work and so no filter required ( all the crap just collects in the bucket).
For dry work it has a paper filter that you attach to motor by an elastic band.
It just collects the dust in the bag instead of dumping it into the bucket.
This main sound really stupid, but what are the main uses for a wet and dry vac?
draining tanks and cisterns
removing water from pipework/under floor pipework to enable soldering
situations with no doc, just cut and suck the water up
cleaning/drying up spills and leaks
once you have used one you will wonder how you managed with out it.
You can pick up the Kamco CF30 for about 800 quid. If you can stretch to it, the CF90's the dogs bx
Reply to the thread, titled "Which wet/dry vac and powerflusher?" which is posted in UK Plumbers Forums on Plumbers Forums.
Nat,
Bloggs,
