View the thread, titled "who/ how is flue put through a flat roof" which is posted in UK Plumbers Forums on UK Plumbers Forums.
plumb_know
Just to confirm all gas work is being carried out by a gas safe engineer and will be registered with building regs. i am pricing for whole house heating and hot water and need to know who usually fits flue through flat roof. boiler is worcester and i have price for flat roof flue flashing but want to know how these fit and is it a roofers job usually. neither myself or my gas engineer have has experience putting flue through roof all previous jobs have just been putting through wall.
The flue is to go through a garage flat roof and the garage is being built in the next few weeks so in this instant would you usually clamp pipe to wall/joists and leave it down to builders to build roof around or would you fit flue through roof afterwards? if so how do you fit the flashing to maintain a water tight seal?
As stated am using a gas safe engineer just need advice about flashing in flat roof really as both of use have no previous experience with this.
Advice much appreciated
flat roofs i would put the flue through stick flashing in place with flashband and then up to the customerto get roofer to permenantly seal
As above and make sure there's plenty of clips on it and screwed as they arnt gental 😀
As its new arrange to be onsite the day the roofer comes to felt the roof then he can go over your flashing kit once you put it into the right place
new flat roof, go for fibre glass then its a really easy job to seal in. Plus fibre glass will outlast any felt roof 🙂
Consider position of joists supporting roof and distance from perimeter or abutments so as not to compromise flashing kit or other roof flashings. Felt should be upturned into a weather collar.
Reply to the thread, titled "who/ how is flue put through a flat roof" which is posted in UK Plumbers Forums on Plumbers Forums.
