Why does gas valve need to be changed after 2 years?
View the thread, titled "Why does gas valve need to be changed after 2 years?" which is posted in Gas Engineers Forum on UK Plumbers Forums.
We have a baxi boiler that's serviced every year
It's 6 years old and had a gas valve replaced in 2020.
A British gas engineer serviced the boiler last year and left it leaking water inside it was all dripping out of the boiler.
Another engineer had to come back and fix it. Before he came back it was leaking for about 7 hours
The circuit board and electrodes are also being changed. Is it likely the leak last year caused damage?
It’s possible, a leak has caused problems, especially if it was condensate from the boiler., as it’s slightly acidic. Have you asked why it’s being changed? Is it part of a repair contract?
It was serviced and he discovered as the boiler when it fires up it bangs he diagnosed that the valve needs to be changed. Im not sure if the leak was acidic but it was coming from the top of the boiler all through down the boiler then onto the floor below so it wasn't coming from the bottom of the boiler. It's in our home care cover but that's not the point. They have caused us problems. They serviced the boiler this year and left us with no water in the taps! And they don't want to come back that day to repair it but another 2 days. I had to fight on the phone to even get them to come back that day to fix the leak.
Oh and when I asked why it was being changed he was trying to get the words out then said sometimes it just happens, they need changing
If it’s part of the cover I wouldn’t be worried too much (I get why it’s not the pint though), but sounds more like the electrodes, could be the gas valve though as mine does it, and happy to leave mine.
Because, you're not paying, someone else is.
Someone is trying to make money out of your situation.
They've changed the parts including pcb board and now its making loud vibration noises when it fires up. He said its air and won't last more than today but I've heard it about 10 times aleady and its been 4 hours since he left. Surely that's not normal
Reply to the thread, titled "Why does gas valve need to be changed after 2 years?" which is posted in Gas Engineers Forum on Plumbers Forums.
Elle48,
ShaunCorbs,
