View the thread, titled "Why has pressure dropped throughout the house after fitting an outside tap?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
The self cutting thing forces a hole in the pipe a bit like a holepunch. The punched bit normally hangs off in the bore of the pipe, hopefully to one side, but you obviously weren't lucky. Sounds like your punched bit is now obstructing the bore of the pipe. You may be able to bend the punched bit of copper to one side of the internal bore and hope it doesn't come loose altogether and run to somewhere it may cause a further nuisance of itself.
I personally wouldn't ever fit one of those kits, but I can see the DIY appeal in that they are cheaper than calling a plumber out - when it all goes smoothly!
Let's hope I'm wrong and it's something else.
You will be correct see it too many times
Reply to the thread, titled "Why has pressure dropped throughout the house after fitting an outside tap?" which is posted in UK Plumbers Forums on Electricians Forums.
