Dmuggy
I'm a total novice so please bear with me. I've just had my annual boiler check from my gas supplier (inc as part of my tariff), and i'm a bit confused. I have a worcester cd24i boiler fitted, it's about 14 years old and so far has only ever needed the pump replacing. The engineer has issued me with a warning notice on the boiler as he said that there is no water discharge pipework from the boiler, and that it has been capped. He said that it would leak if the system was to be over pressurised, and although should be safe to use, it needed fixing immediately. He tried to pressurise the system, which has been on zero since it was installed (as far as i can remember), but although there was a hissing noise the guage didn't register a change. This is the third annual inspection in as many years, and the prvious two engineers tried but failed to increase the pressure, and left knowing that the boiler works. He said that if pipework were fitted correctly, and poss. replacement of pressure guage, the system would work correctly. Currently i can only get hot water if i turn the tap right down to slow, this has always been the case. Anyway, my question is, why would anyone fit a combi boiler, not pressurise it, and not include any pipework should the system need to overflow? Is the engineer wrong, and the system doesn't need pressure? Thankyou in advance for any advice.
