Jun 17, 2023
Tadworth
DIY or Homeowner
Afternoon all,
I have just removed a bathroom radiator and now wondering how to plug the end? Am I right in understanding that I should screw a 15mm blanking cap onto the end of this? Or do I need to install a compression stop?
Thanks in advance for any help or advice
Because that valve has a compression connection, it makes a seal via the olive. So really you should add a small section of pipe and then a compression cap.
A cap, creates a seal with a washer and should be screwed on to a connection with a flat face.
Although not correct, a cap, would work here as long as it’s not tightened so much than the chamfered edge of the valve cuts into the washer.
In a pinch, if I only had a cap, I’d file down the valve chamfered edge to make a flatter surface for the caps washer.
Thanks so much! Very grateful for the help. I'll look at adding a bit of pipe and then a compression cap. I've never done pipe work before so will do some Googling. Thanks again
Hi Shaun, many thanks for the advice. I tried removing the valve but water starts coming out the pipe. I tried turning mains water off but still water runs out, I'm worried about fully taking off the valve? Thanks
What system do you have combi boiler ?
J
UK Plumbers Forums
Deleted member 120897
