will you install the gas pipe work and commission boiler
View the thread, titled "will you install the gas pipe work and commission boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
thats the phone call i've just had, where do you stand on this,the customer has done all the other pipework.
Nope. It's your details that will be logged on the commissioning certificate and who's to say what Joe has left in the pipes etc. Should the boiler go wrong in the future, I'm pretty sure Joe will be coming after you. Not worth the hassle IMHO.
If he's hung the boiler and "done all the other pipework", who disconnected the gas?
Sounds to me as he has started off on the wrong foot.
I plumbed my boiler in (some years ago I would add) and a GSR did the gas side, but he disconnected the gas to the old boiler in the morning, and came back later in the day to reconnect the gas and run through commissioning. The system was power flushed by me beforehand, and I kept the empty containers of X800 and X100 for him to see.
If anyone had asked questions over it, I would have said I was working under the GSR's supervision - he checked everything (at my insistence) and he was happy to put his name to the commissioning documents.
i would only do this if i was to fit and commission the boiler, flue, gas pipework,condense etc....i would be happy to have a customer run wet pipework to boiler position but i would make a point of telling them that you will only warantee the parts (labour) of the install you have fitted, any problems will be charged at a rate.
id have no problem with this provided i hang the boiler its no different to doing a boiler change when all the pipeworks there ,obviously i only warranty what ive done
Money's money as long as you cover your rse. He'll either find somebody else to do it or do it himself. At least it will be right if you do it.
As stated above when you sign it off you are responsible for the integrity of the appliance and flue so I will not sign off unless I've hung the boiler and done the flue work as well as the gas. I'm happy for someone else to do the water side of things.
It's his problem and he spends all the money he saved doing the DIY install, having you diagnose and repair the system faults
a properly worded quote and or report will have you completely covered, as long as you do the whole boiler install then once he sells the house your guarantee will be void anyway as your contract would be with the seller not the new owner,
I had many people ask me to do this when I worked for myself what I did was quote however much I would charge to replace the boiler. Never had 1 taker.
That's what I used to do,but I just say no know. They can't fathom why you want £400 to £500 just for putting a gas pipe to it. And when you try to explain all you get is vacant looks.
Not for me, it's just the kind of people who want to do things like that, normally penny pinchers and everything is to expensive type people, or faf around finding the cheapest bits regardless of quality.
Just saying no takes the fun out of it. I enjoyed the discussions afterwards especially when they said "I thought it would be about £50-£100" My usual answer to that was If I fitted the boiler I would commission it and connect the gas all in the same price.
I did get called some colourful names though. Gave me something to laugh about.
Fair play to someone who trys to put his own boiler up but even fairer play to the ones who get the pro's in to make sure its safe. In my time ive seen some right abortions by gs fitters its all about weather or not its safe. Id do it, but id make it clear ....any problems, if it doesnt work or it turns out not to be safe when I commisioned it thats the custards problem. Id probably do a few extra tests than normal i.e. maybe a little tug to check he hasnt stuck it on the wall with pritt stick and that its level. Apart from that a good visual and check the flue etc basically make surer what you can see done is done to the book. Wheres the condense run is it jumped up to 1"1/2 outside wheres it terminate. The people i hate are the question askers they are the nightmares i make nothing out of them.....how would you .....what can you............if i run a .......there the leeches.
If you dont sort it out someone else will ....
exactly steve... i take it anyone who wouldnt do this has never serviced a boiler without seeing its gas cert first.
Signing off a boiler install and carrying out a gas safety check are two completely different things. When you sign off a boiler you are stating that it is securely fitted, the flue is correctly fitted etc. The only way you can confirm this is if you have fitted the boiler yourself. With a safety check you can only comment that things are working correctly at the time of your visit, you are not commenting on things that it is not possible to check after the boiler has been fitted and the making good done.
is it not also against the regulations to sign off work performed by a non registered person? the only way to cover yourself is to insist that you fit the boiler. As mike says your signing to say that you have installed the appliance. Your also notifying it to gas safe/building control so need to be sure its all correct. Once notified gas safe will offer a free check, if taken up and the inspector gets told by a proud diyer "i fitted the boiler, i just got an engineer to sign it off" you may have to asnwer some questions 🙁
I would charge for atleast days money depending on the gas run and fit the boiler or remove it and refit which should only take 30 mins to an hour in most cases anyway. You will have to flush etc... so would have to deal with any problems with the wet side even if its nowt to do with you to get it commissioned correctly.
Reply to the thread, titled "will you install the gas pipe work and commission boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
desrob,
AWheating,
