View the thread, titled "Window seal and gaps need filling too cold" which is posted in Plumbing Tools on UK Plumbers Forums.
My house seems to be freezing and my double pvc glazing windows were installed over 20 years ago. The window seals have seen better days and there's gaps in between the window frames and window.
Not really done anything like this before as I am not a plumber or carpenter.
Does anyone which seal is best to use around the windows internally? Also shall I rake the old seal off?
Is it an easy job? Thanks.
Not really plumbing, but here's some good advice from UniBond, whose products I've always found to be pretty good.
If you want a good finish it's worth having a practice first as there's a knack to getting the bead nice and even.
If the gaps are more than a few millimetres you might want to use some sealing strip first and then finish off with some gunned silicone.
Reply to the thread, titled "Window seal and gaps need filling too cold" which is posted in Plumbing Tools on Plumbers Forums.
Thread starter
Joined
Location
Yorkshire
Other Tradesman
Thread Information
Title
Prefix
N/A
Forum
Plumbing Tools
Start date
Last reply date
Unsolved
Thread Tags
shocksl,
BN9Pete,
