Wireless stat installation.
View the thread, titled "Wireless stat installation." which is posted in UK Plumbers Forums on UK Plumbers Forums.
macka09
Alright guys. I’m just putting the feelers out ready for tomorrow here folks. I’ve gotta fit a Honeywell wireless stat to a Vokera boiler. I have no experience with either so may need a little help. Cheers guys. Hopefully it’s just a live, neutral and switch live.
Normally Honeywell are
Live
Neutral
Live (normally link from l live to here)
Then switch
Depends which Vokera, one of the new ones you need to disconnect the switching pair from the plug-in timer.
Is it boiler+ compliant 🙂
Live
Neutral
Then switch
You know me mate. Wiring for dummies ha.
You’ve lost me with this ?
Macka,
I think all the advice you need is there.
I would only add that Vokera are not consistent with their boiler control philosophy - they seem to develop / evolve it even within the same range.
Read the MI’s for the model you are working on twice before connecting - the pcb’s are very intolerant of the wrong voltage across connections.
Weather compensation is often through a relay ( to create a second channel for hot water control), that is not present on the early models
Good luck
I got it done chaps thanks. As the new receiver was plastic I didn’t have an earth port so just cut them back and taped. All working fine. Thanks again
Reply to the thread, titled "Wireless stat installation." which is posted in UK Plumbers Forums on Plumbers Forums.
macka09,
macka09,
