May 22, 2022
Hertfordshire
DIY or Homeowner
Hoping someone knows a wiring centre that fits this requirement.
I have 1 UFH zone (3 circuits) and 2 Radiator zones.
Was looking at the Heatmiser UH4 wiring centre schematic, it shows that I can only use zone-4 for a single radiator zone.
By selecting the dip switch to not engage the UFH manifold pump for just zone-4 when calling for heat.
Anyone aware of a centre that would allow for 2 radiator zones and a single UFH zone?
Many thanks
meta
Would it be possible to use the 'hot water' connected zone valve for the 2nd radiator zone.
This diagram is for a heatmiser UH4...
No have you got more ufh as you have the 8 channel one as well ?
I only have 1 UFH zone using 3 heads plus 2 Radiator zones. The diagram is for 8 ufh zones, but still applicable to my 2 zone radiator problem/question. Would buy the UH4 if I could solve this problem.
If I use zone-4 (with dip selecting yes) for rad zone1, then I would want to know if I can use the 'hot water' control for a zone valve on rad zone2. As the hot water would never call to the manifold pump. If this doesnt work, would like to understand why not.
H
3K
UK Plumbers Forums
Deleted member 120897
