View the thread, titled "wiring cm927 to ecotec pro 28" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
ash121
Evening Guys
wireless thermostat has been fitted, when setting the temp the the wireless receiver powers on but the boiler does not fire up
RT24 - 24 V DC room thermostat link has been removed
The wiring has been fitted as follows 4 core cable
Mains connector block
x1 Live to stat live
x1 Neutral to stat neutral
Next to the connector block 230 V AC room thermostat
RT to B stat
RT to C stat
Please advise how I can rectify this, as we have no heating 🙁
get the person back who fitted the thermostat as you need to be gas safe to take the cover off of the boiler to access the wiring
I wish I could however he is away for 2 weeks!, the power has been isolated I am more than comfortable taking the cover off once the power has been isolated and moving the wiring if required
as its an gas appliance you cant so if hes away looks like you have two options (other than reading the instructions etc for maybe a fault on the system etc) one is to get a new gas safe eng to come and have a look or wait for him to come back
sorry to say
sorry to say
I'm not interfering with the gas element of the boiler at all! so I do not understand what the issue is, i've come on the forum seeking friendly advice to rectify the issue which I am more comfortable in doing
no but do you have to take the cover off and havent i been friendly????????
have you checked the basic eg new batteries in range etc?
Yes the cover has to be taken off to access the electronics box how is that interfering with the gas? I'm looking for a solution other than being told I can't do it
really if you take the gas safe law to the letter you cant
I respect your opinion but there is no 'messing' it is merely reconfiguring the wiring if necessary
I've used this forum in the past seeking advice and guidance with no problems in people offering solutions
yea but you havent asked any questions about the internal/ changing anything around
I think it's pretty obvious if the the stat is powering on but not firing the boiler there is an issue with the wiring some where
depends how he has wired it esp with 24v on the pcb etc you should have at the stat 240 coming in and 240 going out
HI I know you have to be on, connections A and B, on the receiver, not B and C thanks.
Its the new vaillant boiler, I have done that, boiler still does not fire up 🙁
Reply to the thread, titled "wiring cm927 to ecotec pro 28" which is posted in UK Plumbers Forums on Plumbers Forums.
