View the thread, titled "wiring cm927 to ecotec pro 28" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all I can help this guy, in this department, I don,t want to upset the apple-cart?
Is this not a forum?
No gas mentioned.
No gas mentioned.
but dont you have to take the cover off to get at the connections? if yes you need to be gas safe if no no you dont
HI shaun I am electric biased, and serve 35 heating engineers, on a daily basis?
I am always inside modern or new boilers?
Our head gas safe engineer, is registered.
Thanks.
Removing the case of this boiler constitutes gas work as it forms a seal.
Unless you are gsr you should not be doing so. Whether you think you know what you are doing or not is irrelevant. You are placing yourself and your family in a dangerous situation.
Turn it off and leave it alone. Then call in someone who is tested and proved to be competent.
Job 38.11.
Reply to the thread, titled "wiring cm927 to ecotec pro 28" which is posted in UK Plumbers Forums on Plumbers Forums.
