Wiring open therm stat
View the thread, titled "Wiring open therm stat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Matt0029
When wiring in an open therm stat. Swapping a boiler and swapping the wired stat on the wall, Honeywell one. For an open therm one. I know you take two wires I believe from the supply to the boiler to the open therm connections in the boiler. Ideal instinct. Am I right in saying open therm is low voltage? I need to get the instructions for the stat and read up. Thanks for any insight.
I don’t believe it matters on OT, as it’s not polarity sensitive, so no switched live. You’ll need L-N-E for the power supply if wireless, and 2 wires for OT. Otherwise it’s just the 2 wires.
The live neutral and earth coming to the boiler would be in the same cable as the stat wires. So I couldnt use this 2 wires to take a feed to the open therm connections? Putting wagos on the 2 stat wires and running heat resistant 2 core to the open therm?
Reply to the thread, titled "Wiring open therm stat" which is posted in UK Plumbers Forums on Plumbers Forums.
Matt0029,
Lou,
