Wirquin neo air trap
View the thread, titled "Wirquin neo air trap" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
WC1
Looks interesting and innovative but falls short imo. Integrated rubber washer to basin waste is good as you can't knock it off and loose it down the back of the carcass but the rubber is thin and less forgiving than my "go to" macalpine . It also fails on the integrated connection to waste pipe. You have to push the waste pipe through the lip seal and then tighten the locking ring. I much prefer to put the nut, slip ring and compression rubber on the waste pipe first.
Not terrible but defo not as good as expected.
Reply to the thread, titled "Wirquin neo air trap" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
WC1,
JCplumb,
