you could have a system boiler and a wood burner linked up to a thermal store, when both heat applicances are used, this would cut down on gas or oil being used as the wood burner would share some of the heat input required to heat the thermal store, the system boiler would also provide heat to rads as well, but using Y or S plan system could be used to divert heat to store when required.
As thermal stores heat the incoming mains water by indirect means (eg a coil inside the cylinder) there is no limit to the amount of hot water that can be supplied, should it be in the summer, then should the thermal store drop by say 6 degrees C. then the stat on side of store would call for heat from boiler. boiler fires up raises temp by the small required amount, then shuts off. If during winter there is a demand for hot water then the wood burner would provide heat as well. there by leaving the boiler to do less work, and more able to concentrate its energy burnt to heat the rads.
Overall this type of system is an excellent way to provide unlimited mains pressure hot water (which a, is always at mains pressure beacuse it doesnt have to go through any delicate combi boiler or require gravity to push it round the house b. will always be unlimited as its heated up inside the thermal store by heat transfer, the level of the stores water never changes no matter how long one runs the taps for. )
Oh and as its all vented no G3 is required! so no explosive cylinder situations,
One would have to install an F & E tank to accomodate the back boiler on wood burner and for the system boiler as this would need a gravity fed system for the rads, but this also comes with a pump so no issues there.
