Worcester 240 BF/OF Scalding hot water
View the thread, titled "Worcester 240 BF/OF Scalding hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
C
campus
Hi Everyone
Worcester 240 BF/OF Combi
Whatever the position of the temperature dial there is always scalding hot water from the tap after a short while
A short time after closing the hot water tap the pump starts and the radiators get quite hot dispersing the excess heat
The boiler does not fire up again when the pump comes on
Any idea what is amiss
Help appreciated
Hi Everyone
Help appreciated
dhw stat i would think
Gents
Thanks for your helpful replies
Do I understand correctly that the variable thermostat on the control panel is for the CH temperature and the Domestic hot water temp is controlled by a fixed internal stat
Campus
The trouble with this boiler is that it works with poor flow rate,which is good but it does need setting up correctly on the hot water side,this has to be done by a competant engineer who can adjust as required to suit flow rate,as stated thermostates can be out of calibration but this has to be check by a engineer who knows the boiler
Reply to the thread, titled "Worcester 240 BF/OF Scalding hot water" which is posted in Bathroom Advice on Plumbers Forums.
campus,
Puddle,
