boydell
Hello All,
My old Combi is playing up again (been OK since I replaced the diverter valve complete 3 years ago), not for the usual failed diaphragm, but for a small leak behind the diaphragm chamber.
Having said that the symptoms are the same ie; central heating OK but no DHW.
I jumped in armed with a Giannoni diaphragm only to find the old one was in reasonable condition. I fitted the new one whilst I was at it anyway only to find no improvement.
After some head scratching I can see that the new spindle is not as far out as it should be in the CH position, and therefore does not reach the micro switches when a hot tap is turned on (just like a defective diaphragm!). The domestic cold water pressure is good (the hot water tap pressure when on is just about equal to the cold.
I have a nagging doubt about generic replacement parts quality (BES LTD were my source for the valve complete).
Have I missed something obvious? Can some kind soul point me in the right direction please?
regards,
boydell.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
