I serviced the boiler and cleaned the heat exchanger replaced the gasket and now it wont fire up. The reset button is flashing but it does not reset. I've made sure the baffles are correctly inserted. I Noticed the White hose( similar to the one on the air pressure switch) not not connected to anything (one side is sonnected to the back of the fan). Should this be connected to something?
