It doesn't have a pilot light. Sounds like you have a fault and need a Gas Safe Registered engineer to come and take a look
Ok thank you for your advice I had it working again as I blew in both white and red pipes also I pressed the switch on the top but all it does is sends the pressure gauge loopy then cuts out again.
if your pressure gage is 1 to 1.5 bar when the boiler is cold, then u need a gas technician to investigate the fault. However if the pressure has dropped well below 1 then you have to repressurise the heating system, normally with a filling loop and key under the boiler. bring it up to 1 bar and the boiler should start working again. if pressure drops overnight, time to get a technician out to do a repair
It has just went out but then come back on again the misus is on the blower to get someone out to it thanks for all your help guys.
The button at the top keeps popping up and when I press it down it comes back on what is causing this ? Sorry I am only asking so I have a rough idea what to say when someone comes out
try hello mate boiler wont work, that will be enough for a technician to start off with.......................
as said please don't mess with your boiler you don't know what you're doing and could do way more harm than good. thread closed.
A
UK Plumbers Forums
Deleted member 120897
A
2K
UK Plumbers Forums
