Was called out to this boiler the other night, no hot water no central heating, boiler not firing. This is the old 28i with the grey front (non condensing)
Anyway, took front casing off and the fan looked like it was struggling to spin, gently blew down the air pressure switch and ignition started. Put tube back on air pressure switch and after a little while the fan began to spin a boiler fired up. I had it down to the fan bearings are maybe on there wag out. Checked resistance on fan, got about 50 ohms, not sure if this is right.
I want to know if I'm know the right track looking at the fan.
What resistance the fan should be.
And what is the operating sequence of this boiler.
Cheers
Hobo
Cheers
Hobo
