View the thread, titled "Worcester Bosch boiler flue." which is posted in Boiler Advice Forum on UK Plumbers Forums.
I
inspire-me
Hi, i am new here and need some advice. My sister has a Greenstar 24i junior it was fitted about 3 years ago and at her request the engineer fitted a right angled flu extension to keep the fumes away from a bedroom window. When she had her boiler serviced recently the (new) service engineer said although the flue is venting at least 4 foot below the roof level fumes may be entering the roof space via the (unvented) soffits. does this sound right?
he might be right thaat the POC's could re-enter via the soffits, if they are not completely sealed, but if the POC's entered via this gap they would be so diluted that they won't cause a problem, a room sealed boiler needs to be at least 300mm from any opening in a building so 4' (1200mm) is 4 times the minimum requirement it cnant be a problem
Thanks kirkgas, just one further question if i may, i have seen /read something about W/B flue terminal's (is that what the end bit is called) can be angled at about 45 degrees up or away from the wall?
Reply to the thread, titled "Worcester Bosch boiler flue." which is posted in Boiler Advice Forum on Plumbers Forums.
