Nov 4, 2017
Lichfield
DIY or Homeowner
Evening Guys,
No heating or water from our Worcester Bosch Greenstar 30cdi conventional boiler.
When starting up the boiler the pilot light comes on for around 30/40 seconds. There is then sharp gurgling noises and the ignition from the pilot light goes out. I did a quick video here which I hope describes the issue better than I do.
Any thoughts would be really appreciated.
right
first issue you shouldn't of really taken the case off as its a gas appliance, and you need to be gas safe to do this
is the pump running? (right hand side green whilo)
Here you go sorry Lighting and quality is poor
How have you confirmed the pump is running ? Is your system fed from an feed an expansion tank or is it sealed/pressurised?
There is hot and cold water header tank in loft then a seperate cylinder tank on 1st floor. It's a conventional Worcester boiler.
I have attached pictures showing boiler and piping.
Hi, As above you have circulation prob, looks like not been properly serviced for a while & also supply cable plug issue.
Call a GSR engineer to come out & sort or possibly W.B. may give you a fixed price repair/service.
Cheers,
Andy (Allgoode Ltd)
Hi ,
Had the same problem few weeks ago & proved to be condensation siphon needed a good clean .
Now works fine.
