Worcester Bosch Heatslave Boiler pressure issue... any thoughts...?
View the thread, titled "Worcester Bosch Heatslave Boiler pressure issue... any thoughts...?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Greetings. I have an external Worcester Bosch Heatslave boiler and have a question about pressure. The boiler pressure was set to 1.5 during a recent visit by a plumber (as it seemed to have dropped and was hovering between the green and red zone) . A few days later I turned the thermostat down so the boiler turned itself off and immediately went to check the pressure gauge and it was at 1.5. I then left it 10 mins and then went to recheck the gauge again and it had fallen to about 1.25. I know that the pressure changes if the boiler is active or not but if the gauge was set to 1.5 during the plumbers visit (boiler not active), would this be the pressure you would expect it to default to again when rechecked when inactive some days later? Many, many thanks for your advice.
Yes also don’t forget when the system is warm it will be higher eg cold 1.25 hot 2 bar ish etc
Have you got any photos of the boiler?
Reply to the thread, titled "Worcester Bosch Heatslave Boiler pressure issue... any thoughts...?" which is posted in Boiler Advice Forum on Plumbers Forums.
Liv Liv,
Liv Liv,
