View the thread, titled "Would one radiator in this space be enough for 6.5 x 3.8m room?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all!
So I've got a 6.5m x 3.8m front room, it's an extension incorporating half of the original living room. I've worked out the BTUs needed but my question is will one rad in this space be enough? Putting two in at half the BTUs each will be a awkward mission but I'm a little apprehensive about only have one in there! Will one be adequate in this type of space? There will also be a wood burner installed too
Yeah that's more than enough I think. Make sure it's a double. What size rad have you worked it out to be? What's the width of it?
And how high is the ceiling?
6.5 metres x 3.8 metres is almost the same size as my Lounge and they put in two radiators (one either end of the room).
I also have a 5.5 KW wood burner in the middle of the room (on an external wall).
The back boiler also heats all my hot water in the winter.
I find that with the wood burner in use I can turn off both radiators and without the wood burner working the big radiator alone is good enough.
I think in your case you say its an awkward mission to put two radiators in so go for one but make it a big one.
On the coldest of cold nights you might decide to rethink things but I would follow Dans advice and go for one.
If you're speaking from experience on the same kinda room layout then maybe it needs to be a big double at least!
Don't be cold on my account
My lounge is 6.93 metres x 4.08 metres with a big double radiator one end and a small double the other.
There are a lot of things to think about but radiators heat the air and air moves about a room (especially if you have a wood burner).
If its a pain to put in two radiators just to have one radiator each end of the room then from my personal experience I did not need the small radiator and you might also get away with one big radiator.
Having said that you could start with two radiators and it is job done (provided you calculated correctly and the room is well insulated), or fit one and add a second later only if it is proven to need two radiators.
I can only share my experience of things in my own home but just because it works for me there is no guarantee
Roughly 2.5kw for a insulated cavity and one 1.4x1 m window
So being a condensing boiler your looking for an output at cataloge around 4.8kw so your looking at two 1400x600k2 or two 1100 x 600 k3
Reply to the thread, titled "Would one radiator in this space be enough for 6.5 x 3.8m room?" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
radiator
tridimnaw,
ShaunCorbs,
