Guest viewing is limited
Zone Valves
View the thread, titled "Zone Valves" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Scott_D
Subscribed
What are the best zone valves in your opinion?
I mostly fit honeywell but as prices creep up I am thinking are they any better than danfoss, drayton EPH?
I've always used Honeywell's.
Mainly because you can remove the motor without removing the valve.
You don't have to drain down to replace the whole valve if only the motor is faulty.
Mind you - replaced plenty of Honeywell motors.
Reply to the thread, titled "Zone Valves" which is posted in UK Plumbers Forums on Plumbers Forums.
Scott_D,
Scott_D,
