H
Is the return pipe cold on both sides?I have checked the motorised valves and I think they are working, based on the return pipe of the zone that is turned off being cold.
I know that's the solution for reverse circulation, but would it work for the OP's problem? The valve would have to be fitted to allow circulation when the zone is open; and there could easily be enough pressure from the pump to open the valve.there is a way around this the installation of a loaded none return valve,
Hi Happyflyer ,
Thanks for all your time and help. Sorry I didn't reply but got called away.
My system looks very much like your first drawing minus the bypass valve part. I cant see that anywhere. However on reading the boiler manual it says there is an automatic bypass inside the boiler, but then goes on to say if the system employs thermostatic radiator valves on all radiators, or two port valves, then a bypass circuit must be fitted with an automatic bypass valve to ensure a flow of water should all valves be in the closed position. Which means you where spot on!
Is there anywhere this could be installed that i would be able to miss it i.e under floor boards or would it be as it appears in your drawing?
One final question does the size of the pipe increase/decrease the pressure? the reason i ask is that it has been installed using a 10mm plastic pipe which seems very narrow compared to the copper pipes coming from and to the boiler.
Many thanks for your help
Fred
