Discuss 110mm Core drill recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Phil
I have a couple of jobs coming up which will require a 110mm hole for soil pipe cutting. I just cant make up my mind on whether to hire, buy a cheap cutter and use it in my Hammer drill (no clutch :mad:) or shell out god knows how much on a decent cutter and machine.
I've already bought two powertools in the last two weeks so maybe I should wait, but then again these holes aren't going the drill themselves and hiring is such false economy. :(
Whatever I get it won't be used every day maybe 4 or 5 110mm's a year but if I do get a machine I will use it for 40mm wastes etc.
Cant make up my mind. :confused:
send a pm to *********, he is the qualified man to answer that one.
May aswell get one, last you a life time, never know when you might just need one in a hurry to finish a job and the local hire place hasnt any in or has been burgled.
Thanks for the replys.
If you got a half decent 110mm cutter say £70 /£90 or whatever they are, how long before they go blunt?
Will my 850W Bosch hammer be enough power to drill 110mm??
if you use a hammer with core drilling you will bugger the bit and break the ends rotary only for core drilling
and knacker your drill, you need a drill with a clutch!
Quite apart from knackering your drill, it will break your arm quite possibly if and (when) the core bit jams in the wall.
My advice is buy a cheap SDS drill with a clutch or a used core drill.. Will save you a lot of armache...
It might well kill your drill. One of the big hefty 1500 watt SDS breakers off ebay for £30 does it though as Ive used one for a couple :D . Not on hammer mode of course.
Oh, and they get VERY heavy with the time it takes to drill a core through a hard wall, so I would advise a proper core drill!! a good book, and a seat
Yeah difinitely need an sds I did one a few weeks back and it still took a couple of hours.
I can highly recomend the macrist core drill ddm2.DDM2 Hand Held Drill | Marcrist. I bought mine from a macrist rep who visited a hps branch in dover for about £160 when it was still a prototype. Beieve me once you've tried this baby you will never use another core drill again. If you google marcrist ddm2 and click on shopping you can find it for about £250. worth every penny! Also it is a very fast machine.
Reply to 110mm Core drill recommendations in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sonya K
