Discuss 110mm elbow spigot to pan connector in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi can I insert a pan connector Finn's straight into the pipe end of an elbow spigot ? I'd rather use this fitting then an elbow with pipe
Many thanks
Put some 110mm into the fitting enough so it’s flush with the front eg the insert / collar depth
And then just push your pan connector in
The socket end of the elbow is going onto the soil pipe, but the other end the spigot part which is just like pipe I'm wondering if the pan connector can go straight into this? I know these ends are made to go into other fittings just like pipe so I assume this will be okay to put a direct pan connector into ?
It's like the male to female 110mm elbow which I attached which I'm using.
Yep straight in
I wouldn’t
Reply to 110mm elbow spigot to pan connector in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
