Discuss 22mm fittings to old 3/4 pipework. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have always used my local plumbcenter. They've always had either the 3/4 olives or the imperial to metric end feed sockets!
peat you can get 3/4 to 22mm endfeed converters as mk_swans said
I don't think you'll have much joy with an end feed coupling I've just had similar issues in a bathroom refit connecting onto old pipe work tried a 22mm end feed elbow to join new to old and the solder wouldn't bridge the gap on the old pipe work I ended up using a 22mm speed fit push fitting
Is that wise? Surely the 22mm Speedfit O ring is too slack on the 3/4" pipe & worse still, the gripper may not hold?
Peat, I meant 22mm to 3/4 converters/reducers.
Old pipe, coupler, New 22, valve, New 22, coupler, old pipe.....see what I mean?
You need to get back to that job ASAP and remove that fitting before the place floods.
What a bodge.
Dont just lash the end feed couplers into your box as then you will spend ages finding they are no good on 22mm pipe like i did a few months ago and they still surface to my annoyance CHK
Youre kidding right?
you dont use a 22mm coupler!!
you use a 3/4 to 22 mm coupler for imperial to metric to convert it.
as for 22mm speed fit on 3/4 copper pipe.........
i hope you have decent insurance......... Because you're sure gonna need it
Thread a piece of earth wire through your 22mm x 3/4 connectors & twist the ends together & you won't get them mixed up with ordinary connectors.
THese fittings used to a have a green end - not nowadays.
I cannot see the difference - my eyes are going so I do most things by touch ! CHking
Lol your eyes must be going if you can't see the difference CHK
Reply to 22mm fittings to old 3/4 pipework. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm trying to connect 3/4" copper to 22mm copper in an old house. However it appears that the 3/4" is actually slightly smaller (measured at...
I'm a kitchen fitter first and foremost, so occasionally encounter old pipes of varying sizes. From past experience I know how easy it is to...
Hi I've had to cut hot and cold feed to re route for bathroom feeds. The 22mm Copper pipe hot feed is slightly smaller then my 22mm Copper...
… praying to the plumbing God, Bob Pictures and layout details attached, so be patient. 21 year old oil fired system in pretty good nick. I...
Hi. I'm currently estimating on installing a new shower pump to feed an existing bath/shower diverter. Hot side: fit flange and spherical valve...
5K
