C
coup27
I am upgrading my existing vented cylinder + 2x loft tanks setup for an unvented + no tanks setup. I am not a plumber and won't be doing this work myself. I have had 3 quotes for the work along with my other plumbing changes and I have a few questions I would like advice on.
1. 1 of the 3 plumbers has included to install a new 22mm cold main pipe from the incoming stop tap to the new cylinder. Can someone advise me on why only 1 thinks this is required? The house was built in 1988.
2. All 3 plumbers have proposed different cylinder sizes, 110, 150 and 210 litre. The house has 3 bedrooms and 2 bathrooms. The main bathroom will have a shower bath and the en-suite just a shower. There are 2 people living there. From my own research I think a 150 litre should be enough but I would like some feedback on this. Incidentally, it is the same plumber who wants to run a new pipe that has proposed a 210 litre cylinder.
3. Is there any benefit to a chemical flush if you install a Magnaclean and empty it out a few times after recommissioning?
Thanks.
Thanks.
