Discuss Advice on leaking overflow pipe from back of boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
SuperMarryO
Hi everyone,
I would really appreciate any advice you might be able to give me on resolving the following problem please:
I am a diy plumber and I have just replaced my bath suite in which I had to isolate the water from the mains stopcock on the road. Since I have switched the water back on and everything is fitted I now have 2 problems as follows:
The water pressure from the hot tap on the bath is poor
When I run the hot tap there is water pouring from the overflow pipe that goes outside from the back of the boiler
Can anybody please advise me why this might be and how to fix them?
Welcome to the forums.
Post the name and model of the boiler for the guys.
Either filling point on boiler is open or damaged what make boiler do you have ?? you may need to call out a gas engineer if problem is inside the boiler.
Other than checking your filling loop is turned off there's nothing more you can do.
You need a gsr.
Reply to Advice on leaking overflow pipe from back of boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have done pressure test for 2" high pressure pipe line by closing the pipe with rubber plugs at the ends. It was 3 bar and I kept it for 24...
Sonya K
