Hi All
I am looking to fit a 600mm dishwasher, i will be fitting it under counter in a current 600mm 3 drawer carcass (i presume this is ok once all the drawres/side sliders are removed?)
From left to right i have sink unit (single waste outlet on trap/u bend), space for washing machine (600mm under counter), 600mm space for freestanding gas cooker, then i propose to fit the dishwasher in a 600mm ex 3 drawer carcass.
I have CW and HW end valves behind the w/machine and it's waste easily reaches the sink single waste connection.
I plan on swapping the CW end valve for a T type one (feed w/machine) and then extend the existing 15mm copper with plastic and correct inserts and reconnecting the end end valve to use on the d/washer.
Would this be ok to run behind a gas cooker?
Once i know what to do with this i will ask about the d/washer waste....
Cheers
Cheers
