Discuss Alpha 2l pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MZR
Hi all
got called out to service a boiler today asked customer if there's any problems ? Oh the heating not worked for 3 weeks ! So switched the heating on to the Icos 12he boiler fires up then burner goes out and burner light flashes, I went to check the pump to find the new grind dos alpha2l pump , any ideas how to check see if it's wirking ? The power is on as it displays "on" but I'm not sure if it spinning ? I pressed the arrow under the display but nothing changed ? Unplug it and plug back in I see the lights all come on them they go down one by one until off ? The pump sounds like it's pumping but what carnt check it any ideas guys
are thes pumps meant to show the speed of the pump when on ?
Cheers all
ALPHA2 L | Grundfos
Push the arrow button so that you have the the lines on the left on, thats speed 3.
The display should show a number, at speed 3 this should be in the 40's. If it isn't then it isn't shifting water, these things can be a real to clear air from.
These need to fitted properly or will give issues.
Make sure fitted on correct plane and cable drops directly down from bottom of pump.
Put on to stage 3 and run for about 10mins to clear air from pump. Then should show 40-45w on display if all is well.
Reply to Alpha 2l pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, Can I pick your brains? My boiler is often reluctant to start, sometimes it does, sometimes it seems that it will if the demand is from the...
1K
Woke this morning to no hot water but heating was working fine. Checked the forums and checked all the common problems: Water and boiler pressure...
Deleted member 120897
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical...
5K
  • Locked
Hi, Please can someone help identify if there is a problem with my heating system. A few days ago it seemed the boiler was trying to light...
2K
Hello All- (Usual caveats apply: I am the rather unusual part-time variety of a GSRE, training self-funded and slowly trying to make my way and...
