Discuss Anyone know how to close stiff stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Any advice appreciated as I can't turn off a stiff stockcock under the sink
Adjustable spanner on the tap head, gently does it wiggling side to side, usually goes after a few times, but Scott’s is sound advice as well.
Many thanks as well. If I wiggle the tap head gently is it possible that I can do damage and water will go everywhere when the mains is back on?
If you mean coming from the stoptap itself then no not usually, if it’s too stiff you can break them, but can be hard to do that. As a Rob has suggested try a lubricant of some sort.
Reply to Anyone know how to close stiff stopcock in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know where I can get one of these? Toilet is leaking into the bowl. This one pushes in with a half turn but I can't find one anywhere.
