K
keynet
I have a 5yr old Vaillaint Ecomax 622 system boiler with radiators, Megaflo cyclinder and under floor heating manifold, each controlled on a separate Honeywell valve. The system was new with the boiler (house renovation) and has MB1 in it.
Recently the boiler started short cycling on the UFH (only), manifold input only getting to about 45C before the boiler return gets to about 60C in less than a minute. The temp of the pipe on the bypass inside the boiler (where it meets the main return) is much hotter than the return, even when the hot water cylinder is on. When *only* the UFH is on, the main return is only tepid, the bypass pipe pretty much at flow temp - hot! I'm pretty sure the UFH circuit is clear, though the manifold will provide more resistance than the tank. Theres 1 bar of pressure in the circuit. I'm thinking maybe the bypass is bypassing when it shouldn't, as the return into the heat exchanger is significantly hotter after the bypass, even with the hot water on, which should provide a pretty decent return rate (and the cylinder does heat up reasonably quickly, boiler doesn't short cycle when the water is on). The boiler isn't reporting any faults.
So -
1) Is the bypass likely to have failed?
2) Any kind of tests I should run or other things to look at before replacing the automatic bypass?
Thanks for any advice!
So -
